Forum: Beta Builds Regression Bugs
Topic: BUILD 2067
-Fix bug with pitchQuality 1 for looped samples
-Fix some video slideshow crash
-Fix video slideshow time to max not playing videos till the end
-Fix regression unable to resize skins
-get_sampler_bank_id and get_sampler_bank_count
-fix for midi text out using sysex
-fix switching sampler from unmute trigger mode to different mode
-fix some sampler crashes
-fix sampler_rec not working when remix mode selected
geposted Thu 27 Nov 14 @ 10:21 am
This latest update has my system crashing any time I move a platter on my NS7, You should be getting the logs. Im on a Macbook running Mavricks.
On mac will not open from BUILD 2048 - PUBLIC also... 2064 & 2067
OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
If this issue is not new to this build then it is not a regression bug for this build and should be reported in the correct forum.
In your case I would remove settings.xml from your Documents\VirtualDJ folder and retry. If it still doesn't work this file a bug report here:
https://virtualdj.com/forums/75/VirtualDJ_8_bug-report_Forum.html
FOR TIMECODE VINYL
With this update when i hold the platter on the turntable and get ready to mix in the songs it jumps in the beginning of the track and lose sticker drift when it jumps i am using SL3 BOX windows 8 / I7 16 OF RAM and i did a fresh install to .
And still the timecode vinyl off and on button still not working right when i turn it on and off on the software it make the track jump.
loaded a karaoke file and wouldn't play so loaded another and it played . I then loaded the original file and it played but sound popping so played it again to see if the sound popped in the same place but it didn't . Im still not using this live because of these issues arising. I have reported other issues in the past and asked questions but ignored.Why? some recognition would be good as the question still remains . Are we going to get the feature back where we can just drag and drop from the side list to remove file. When I do this I end up with a file in my side list and bottom side list. Also when I try to enable VDJ 8 whilst using 7 it wont open ?
Another issue which I have just found is that I cant drag a file onto the decks from a folder in my desktop VDJ8 2067,887 earlier I could.
Rezise skin persist in fruit
Image repeated dislocation
PNG/24Bit/945X945/Adobe Photoshop
