I'm curious, with the Pioneer DDJSX-2, if I do a backspin on the platter while a song is playing, and don't finish the backspin, but hit a hotcue button while it's still backspinning; wherever in that backspin the "position" is at; gets SET as that hotcue point, rather than actually going to that point if it has already been set; another words, it automatically deletes the previous hot cue and replaces it with another random hot cue during the backspin; is that intentional; ??
I want it to go to the hot cue that I have set already to continue my song; not set a new one at a random spot during the backspin.... Is this a glitch or ??
geposted Thu 27 Nov 14 @ 7:39 pm
It shouldnt happen, so probably you use the "Temp/Serato" HotCue mode ?
If so, then yes it could happen, as this mode is a complex script/workaound to offer this mode, so there could be cases where this doesnt work correctly.
If you dont want this behavior, then you should probably choose the "Normal/default" mode. (selection is made with SHIFT+PRM buttons)
geposted Thu 27 Nov 14 @ 7:45 pm
You were dead on, thank you; I didn't realize such a thing existed (don't use serato much; prefer VDJ)... I must have somehow hit the combination of buttons during setup/testing... I recalled it was working "normal" before so that's why I questioned it... thank you again; I wonder if there's a way to know which "mode" you're in; it doesn't really say anything or give a notice if it's changed anywhere I can see... but it's working, took a couple presses "randomly".... :)
geposted Fri 28 Nov 14 @ 1:18 am
Its not something that you can see/change from the software. Its a mapping mode. An Operation guide for the functionality of the DDJ-SX2 will be available soon, but in the meantime you can see the DDJ-SZ one, which has similar operation for the Pads https://virtualdj.com/documents/Pioneer%20DDJ-SZ%20-%20VirtualDJ%20Operation%20Guide.pdf
geposted Fri 28 Nov 14 @ 4:11 am
