I would like to incorporate in settings to choose the pitch reset time option. Tnx.
geposted Fri 28 Nov 14 @ 12:37 am
There is no setting for that. The speed of the pitch reset can be defined using a % parameter in the pitch_reset action.
E.g. pitch_reset 5% will move the pitch back to zero with a speed of 5% per second (1% is the default value)
geposted Fri 28 Nov 14 @ 12:41 am
I know, I wish that were in configuration to setting it permanently.
geposted Fri 28 Nov 14 @ 1:29 am
It would be useful to assign it to a custom knob with variable %.
geposted Fri 28 Nov 14 @ 5:04 am
like effect, ¡good idea!
geposted Fri 28 Nov 14 @ 8:11 am
and a bpm stop option! :D
geposted Fri 28 Nov 14 @ 8:14 am
Can sort of be done if you add multi queries to the reset button X=Y? rate A : X=Z? rate B
geposted Fri 28 Nov 14 @ 10:07 am
