Topic: Beatlock bug
geposted Fri 28 Nov 14 @ 2:02 am
It seems to me, that this is not a bug of VDJ...
Do you play your songs from an external device ?
The same problem in these two computers, with and without dj controller with external sound card and onboard sound card.
Intel Quad Q8200 2.33 Ghz, 4gb ram, geforce 9600gt 1gb. 500gb wd hdd. Windows 7 64 bit
Intel Core i7 3610QM 2.3 Ghz, 6gb ram, geforce 630m 2gb. 1 tb hdd. Windows 8.1 64 bit
Sound cards and controllers tested:
2 Pioneer Cdj 350
Reloop beatmix
Numark DJIO
Internal realtek soundcard
Is it really normal to push the pitch +30%?
I use it for extreme changes in musical rhythms. if deck 1 goes on 130 bpm and i wanna mix a 110 bpm deck 2, you need a extreme pitch diference. But thats not the problem, the problem is that in my case the software it is not handling well.
130-110 is less than 20%,
The bug occurs when the pitch difference is less than the difference to the 1/2 | 2* speed, so 100-133ish would be a prime candidate,
For large differences instead of using beatlock use pitchlock.
