-Fix scratching jumping to loop position when loop is further down the track
-Fix reading interlaced png files
-Fix track edits with just an image not opening as video
-Fix search action not focusing edit in multi-browser skins
geposted Sun 30 Nov 14 @ 5:10 am
Thanks Adion,
PNG image has perfect to overlay,It's a good job.
geposted Sun 30 Nov 14 @ 10:45 am
By the way,
Don't forget to correct the wrong translation code field.
geposted Sun 30 Nov 14 @ 10:48 am
"-Fix scratching jumping to loop position when loop is further down the track"
thank you Atomix.
thank you Atomix.
geposted Sun 30 Nov 14 @ 11:10 am
Add a video to MP3 playback, doesnt seem to work.
I may have done something wrong in the settings.
Any suggestions?
Any suggestions?
geposted Tue 02 Dec 14 @ 2:12 am
My samples doesnt sync right, even when I have edited the cbgs
geposted Tue 02 Dec 14 @ 2:26 am
I continue to have the crash in automix with this version (use mp4 video)
geposted Tue 02 Dec 14 @ 3:36 am
@ErikVeejay
as i told you in the ticket , we've received your crash report and will be analyzed.
geposted Tue 02 Dec 14 @ 4:04 am
Crash in Automix only on Osx 10.8.5
geposted Tue 02 Dec 14 @ 12:43 pm
This LAST update...NOW CRASHES ON ME!?
I have a MacBook White (2.1 Ghz Intel Core 2 dUO, 4 GB RAM),
Running VDJ 8----> with a Numark MixTrack2, and a Stanton SCS.3D.
^----This setup has WORKED for me threw all the VDJ8 updates...
But!!!! THIS LATEST UPDATE has my program CRASHING,
even when just hitting a "backspin" effect. This has never happened before..
Very UNSTABLE
Very UNSTABLE
geposted Tue 02 Dec 14 @ 4:59 pm
Running VDJ 8. MAC os 10.7.5
*When I delete a Folder, Or Playlist...MY WHOLE Program shuts down.
geposted Tue 02 Dec 14 @ 5:03 pm
OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM work ok here
geposted Tue 02 Dec 14 @ 11:45 pm
I had the same problem ,I update to yosemite and problem gone.....
geposted Wed 03 Dec 14 @ 1:38 am
Any suggestions?
Any suggestions?
This works now..
geposted Wed 03 Dec 14 @ 4:03 am
Just an FYI... This is not working... -Midi clock output setting stored in config. This setting needs to be set each time I open VDJ8. I do not see a setting in config for midi clock.
geposted Wed 03 Dec 14 @ 10:02 pm
just had several crashes on 2073, I was online, I hope the reports got uploaded to Support
thank you
thank you
geposted Thu 04 Dec 14 @ 10:45 am
I hope u guys are aware that the RANE SL3 SOUNDCARD HAS a audio glitch when scratching can not get rid of it i try everything.TIMECODE VINYL need some help or is it the SL3 driver for it or the VDJ 8 software ?
windows 8.1 cpu I7 ram 16gb.
geposted Thu 04 Dec 14 @ 11:57 am
more crashes, when connecting/disconnecting controllers, tried with stanton scs1d(firewire), vestax vci-100(usb), I was also online.
thanks
thanks
geposted Thu 04 Dec 14 @ 12:06 pm
thanks
thanks
Nothing received here. Try to start VDJ whithout any controller, then connect it
geposted Thu 04 Dec 14 @ 3:04 pm
None of my video samples arte working, they are all present and the mapping on my MC6000MK2 for sample bank is not loading/triggering any of my video samples [edited] ???
When I plan a video, say mp4 file in the sample bank, it is a faint background which you can just about make out, otherwise all my video samples whether fixed or transparent do not work now ???
Thank you
Thank you
geposted Thu 04 Dec 14 @ 6:43 pm
