Topic: Delete from Playlist
When I try to batch 'delete' songs(i.e. permanently delete songs from the database) when they are in the playlist, the songs are still remain in the database.
Is this a technical issue? Thanks for your assistance. FLeX
geposted Mon 01 Dec 14 @ 8:55 am
Do you try to delete them in the Playlist-window ?
In that case VDJ only deletes the files in the playlist.
If you want to delete them completely, then you have to delete them in the main browser window.
Hello djragman and thank you,
Yes I try to delete from the playlist window. I can delete from main window or create a temp folder when batch selecting files and delete them that way. But why the option to delete and remove are available on playlist window? It appears to do the same thing-just remove files.
No, it doesn't. It only deletes the entry of the song in the playlist
