Topic: build 2073 bug running videos
Using MacBook Pro OSX Yosemite vers. 10.10.1
Intel HD Graphics 4000 1024 MB
with Mixtrack Edge controller.
when cueing up another video vdj 8 crashes immediately on either deck, if you don't cue, or use effects, they will play w/o crashing, its when trying to loop, add effects, or cue thatvdi 8 crashes, ...last stable build was 2048..
Cheers..
geposted Tue 02 Dec 14 @ 7:16 am
Might go w/o saying but for each major update, backup or rename the settings.xml and re-install. Seems to cure many OSX ills.
