Topic: hold to play
Hi all. Quick question. is there anyway to have hold to play option on the cue points?
geposted Wed 03 Dec 14 @ 7:03 am
I think you can map a button to this. I recall someone at some time requesting a similar feature.
I think that would be the while_pressed command.
Adding that to the cue buttons already on the skin would mean editing the skin XML, but you could do it with custom buttons.
pause ? cue x ? cue x while_pressed : cue x : cue x
Try that in place of your hotcue mappings X = cue number.
Ok cool. Thanks. Ill try it tomorrow
That one only does the hold to play when paused, is that what you're after?
im looking for while playing
not exactly sure what you re after...Try this too..
replace hot_cue x with cue_play x
If pressed for more than 2sec and then release, the track will continue playing. If released earlier, it will go back to the cue point
You can also specify the "delay" using .. cue_play x 3000ms
I'm a bit confused, explain exactly what you want to happen
I'm playing a track and when I press the button This happens and when I stop pressing the button this happens
try
hotcue X while_pressed
