virtual DJ 8 help please
I was recording my radio show using virtual DJ 8 it will only recored the music and not my voice when I am speaking into the microphone. I have an American audio midi VMS2 mixing system. what I would like to know is how do I get this to work properly or what mixing system will do both. I was going to use audacity to make my radio shows that will not work at all
can you please help or advise me
Thank you
Andrew
Thank you
Andrew
geposted Sat 06 Dec 14 @ 11:18 am
In VDJ-8 you need to set it up for mic and the skin has a mic control on it Dj fruit has one I use with the mix on my RMX only using the mic in VDJ-8 will see a input ch...I played with some time ago and just use the Ex-mic source and not record my voice just music...this may help you get started and just play it it and save the master setting and rename the mic.
geposted Mon 08 Dec 14 @ 12:35 pm
