Topic: VDJ8 crash on mac
Hi, I have a macbook early 2008 with 10.7.5 os 2.4 GHz core2duo and 4Gb of RAM. VDJ version is 2073.890 and I have Pioneer DDJ-SX2 controller with firmware 1.04. I just switched from VDJ 7.4.1 and DDJ-SX because of spilling of fluid over the SX during the gig. So, the program randomly crashes during the night. I've noticed that it crashes if I turn the jogs counter-clockwise while the song isn't playing (setting the cue point) or if I try to manually align the beat with the jog wheel. There is no prior warning. The program just shuts down and resets all the settings to the UI I have made (BPM, Play count, Grid size...)
My CPU usage is never in the red.
I still have the VDJ 7.4.1 installed on this mac but i don't think that this maybe the problem
Please help
geposted Sun 07 Dec 14 @ 8:59 am
Mac lion is a bit buggy with vdj 8. I have some strange crashes that occur as well. Since you can't upgrade your Mac due to its age the best option is to bootcamp and run windows. It works pretty much flawlessly. I'm sure the devs are working on the lion issues but since it's such an older os. It may not be a priority
J
have you opened it up and made sure its all dry on the inside?
could be there is still some liquid in there effecting those functions.....
next thing it may not work at all
the sx is in repair shop and i've bought new sx2
sorry i didn't realize this disregard my comments :-)
there are other having issues with the SX 2 have a look in the hardware forums
OK. So, if i upgrade my mac (buy a newer one that can run mavericks or yosemite) the bugs might go away?
Thank you for quick reply
Vdj8 runs very well on mavericks
Thnks for the tip. My next move is to buy a new mac :-)
Please help
HAVING THE SAME PROBLEM !!! last update 2073.890 has a bug can´t touch the jog wheels VDJ 8 shuts down instanly i use yosemite and ddj sx and until this week had no problems
+1 ,
random crashes backspinning, on SCS1d and VCI-100, osx 10.7
Fixed the ddj-sx...
i've pluged it to VDJ8 and.... also crashes
@dag0407, when i check your updates i can see you do not use the latest build from our side.
Please download the Free version from our side and install it.
http://www.virtualdj.com/download/index.html
Enable get Beta at VDJ Config - Option side.
I'm sure this will solve your issue.
i've seen that new beta build has been released.... i will download it today and try
same here, macbook pro, MC6000 crashes when touching the jog wheels, went back to a previous build and its ok.
Installed the latest beta build 2087.896 and it works with NO problems. Worked on it all night and everything is OK.
Low cpu usage
OS X 10.7.5 4gb ram macbook
thx
