Forum: Old versions
Topic: Numark N4 VDJ quitting when i move jogwheels
Hello, I've been having this issue recently since I got the latest version of VDJ 8. I have a Numark N4, and many times when I'll move the jogwheels slightly to move in a song, whether it's on the touch platter or on the sides, the program suddenly quits without notice. I have been trying to figure out why this happens, but to no avail. Any ideas/help would be greatly appreciated.
-DJ MG
geposted Tue 09 Dec 14 @ 7:42 pm
Thanks for all the help everyone... not
Hi, Be Rad B!
I had a similar issue with my Denon MC3000 after the last software update. I posted on here regarding this and was told I should enable the Beta Builds to download which should fix the issue. Here is what they said "This should have been fixed with the latest beta build 2087.
To get the beta build, enable this option from your Account or from the Advanced Options from VirtualDJ (getBetabuild setting)"
I went into settings and enable the getBetabuild option and the problem is now FIXED!!! I hope this works for you!!
Cheers!
Duane
