Forum: Old versions
Topic: Updated Virtual DJ8 crashes on Denon MC 3000
I've been using VDJ8 with my MacBook Pro and OSX v 10.8.5 with virtually no problems and then when I opened up VDJ8 the other day (probably Dec. 7) and started Djing, the system crashed when I was scratching the right turntable jog wheel. I moved the jog wheel back and the program came back up but then crashed again? Is there a way to go back to a previous version as I have never seen this situation before?
geposted Wed 10 Dec 14 @ 11:39 pm
This should have been fixed with the latest beta build 2087.
To get the beta build, enable this option from your Account or from the Advanced Options from VirtualDJ (getBetabuild setting)
Thanks very much dcomo and djdad! Will try that!
Yay! I enabled beta build download and problem fixed! Many thanks!
