looking for some help on getting this card set up in virtual DJ. does anyone know what the settings should be in the config sound?
geposted Thu 11 Dec 14 @ 7:56 pm
You are aware that this audio interface only has one stereo output, meaning that you will not be able to get independent mix and headphone output ?
geposted Fri 12 Dec 14 @ 6:46 am
Hello Dj Phatso , i need your help ... Im trying to setup my home studio but im having problems with setting up my hercules rmx with virtual dj 7 , scarlett 2i2 2gen audio card , and 2 timecodes ( denon DN-S3500) , so far i tried advanced config because i want to use the sound from the audio card instead of the rmx (the sound using rmx is bad) and the best i could get is good sound , but the 2 timecodes come out of only 1 fader , becouse it says i can only set the up at inputs 1-2 , and thats the only options ... I would be really thankful is you help ! :)
geposted Fri 23 Mar 18 @ 2:11 pm
ps : i got 2 rokkit krk 5 g3 connected to the scarlett
geposted Fri 23 Mar 18 @ 2:14 pm
You can't run two stereo signals into or out of the 2i2 - it doesn't have enough channels.
You need something with two stereo (or 4 mono) inputs and two stereo (or 4 mono) outputs.
geposted Fri 23 Mar 18 @ 5:44 pm
So will a scarlet 2i4 work good for me than ? Or should i just get a better mixer (with a better built in soundcard) , and connect my monitors and timecodes directly to it , without using a laptop ? If you have some suggestions , for what exactly to buy ( in both scenarios) i will be thankful to hear them :)
geposted Tue 27 Mar 18 @ 9:04 pm
