Topic: Virtual Folder Permits Duplicate Track Entries
The VirtualFolder feature in VDJ8 permits the user to add duplicate tracks (with same absolute path) to the same VirtualFolder. Considering that a DJ may have many songs (on the order of hundreds or thousands) in a given VirtualFolder, they may not remember that they have added the same track to the VirtualFolder before. The expectation is, if the user has added a track with the same absolute path before, Virtual DJ should not create a duplicate entry in the VirtualFolder. Instead, adding a track to a folder should be an idempotent operation and VDJ should simply not take any further action if an entry already exists in the VirtualFolder.
Reproduction Steps:
1. Add a track at path /a/b/c.mp3 to VirtualFolder A
2. Repeat Step 1
3. Notice that there are now two entries for c.mp3 in VirtualFolder A
geposted Sat 13 Dec 14 @ 1:04 pm
It seems to be only a temporary visual issue.
The file is not actually added a second time, so if you open another folder and come back to the virtual folder you'll see that the song is in there only once.
Very interesting...Thanks for the reply!
