Hello,
I use the Denon Asio 2.22 Driver with a Denon HC 4500 and a very fast new laptop. What is the difference between Ultra Latency Asio option and not having that option checked off? What is the benefit of checking it off?
Thank you!
Thank you!
geposted Sun 14 Dec 14 @ 1:04 pm
Don't know if its the same with V8, but that was once written for version 5.
"Ultra-latency ASIO – There are two ASIO engines available for VirtualDJ to provide better latency support. Checked is the original ASIO engine that is optimised for very low latency (renamed ultra-latency) and is still considered the default engine. Some computers have problems with this optimization. Unchecked is the NEW 'safer' performance level ASIO engine which has less optimization for environments that have difficulty with the Ultra-Latency engine."
https://virtualdj.com/forums/85090/General_Discussion/Ultra-latency_Asio_in_version_5_0_7.html
And another statement:
cstoll wrote :
Ultra Latency has nothing to do with how good a processor is in your machine. It actually has to do with the how good the quality of the drivers are for the device you are using. And for the Hercules products you should be able to use the Ultra Latency checked.
There are some ASIO devices out there that have shotty drivers by unchecking the Ultra Latency option there is a slightly difference process used in communicating with the device.
geposted Mon 15 Dec 14 @ 7:41 am
