Forum: VirtualDJ Skins
Topic: American Audio VMS2 1366X768 Skin
bdmo186PRO InfinityMember since 2010
Where can I download the 1366X768 VDJ skin for the American Audio VMS2??? I can't seem to locate this particular skin anywhere. Please help......................THANKS!!!
geposted Sun 14 Dec 14 @ 4:30 pm
Dodge57PRO InfinityMember since 2009
geposted Mon 15 Dec 14 @ 7:37 am
The VMS2 skin is installed as part of the VDJ LE software which ships with the VMS2. The installation package is also available on the VMS2 web page.
The supplied skin is only available in one resolution (1280x800).
If you require a skin for 1366x768 then there are a great many VDJ 7 skins available in that size. Download/Addons/For VirtualDJ 7
geposted Mon 15 Dec 14 @ 7:57 am
So basically what the both of you are saying is that there is no downloadable American Audio VMS2 controller 1366X768 skin? I know what skin comes with VDJ LE and I have looked as well as searched the skins on VDJ before I started this thread. And there is no VMS2 skin for VDJ8as well...........Thanks anyway for both of your inputs.
geposted Mon 15 Dec 14 @ 11:55 am
As far as I'm aware, there is no VMS2 skin in any other resolution.
Your post implied that one existed. Did you see one or hear/read about one somewhere?
Hopefully you're aware that it's not a requirement to use a skin that looks like your controller. You can use any skin.
geposted Mon 15 Dec 14 @ 12:08 pm
geposted Tue 16 Dec 14 @ 12:26 pm
Hi bdmo186
I have the same controller as you and my ultrabook uses the same resolution as you 1366x768. There are NO 1366x78 VMS2 skin that comes with VDJ LE software but what I did is download the skin resizer tool and resized the skin to 1366x768. Works like a charm.
geposted Sun 04 Jan 15 @ 5:17 pm
