Hi Support,
I have an issue with setting VideoForceFullScreen = 1
When set to 1 it freezes the video - When set to 0 it plays it's OK
I have two graphic cards in my laptop: Intel HD4000 and Nvidia GT630M
I have tried both cards with VDJ and they both give me the same result as above.
I have tested with PC Build 2087 898 and PC Build 2090 896 and both fail.
Many thanks.
Many thanks.
geposted Fri 19 Dec 14 @ 2:37 am
You should use ForeFullScreen = 1 only if you got a dual video card lapop AND have problems displaying videos.
Otherwise leave it on 0.
geposted Fri 19 Dec 14 @ 4:12 am
ok thank you for the reply
geposted Fri 19 Dec 14 @ 7:13 am
