Forum: Old versions
Topic: Sound Card Error Help Plz
I Have The Mixtrack 2 I Have Virtual dj le and when I open it it says ''error in the sound driver your sound driver is probably not connected or the settings are incorrect'' then I press ok and when it opens up I cant play any songs I tried uninstalling and installing that does not work I tried restarting my computer tat doesn't work plz help me.
geposted Sun 21 Dec 14 @ 1:51 pm
Have you checked the Config/Settings to ensure the correct soundcard set up in Virtual DJ?
You could also check to make sure the device drivers are installed on your computer.
Thx danny i fixed it
