Topic: Video recording
been having issues with recording video live video feed is perfect no choppiness at all. but when recording the resulting video result has slight choppiness tried adjusting frame rate using less effects etc but with same results. in video setup using telly visuals, telly media, milkdrop plugin no other effects. is it possible to use other video codecs with virtual dj 8 than the ones provided I know 7 allows it but can't figure out if 8 allows.
geposted Sun 21 Dec 14 @ 8:06 pm
