Topic: Software freeze and sound stops
hi , I am having problems with vdj v7&8. I have recently purchased a new toshiba laptop with windows 8 installed. Once I down loaded my vdj full version software from my licence page and installed, when I play tracks It can work for 2 min or an hour before it he interface freezes and I loose sound. The track still plays in the virtual deck but my controller does nothing. I have set the audio speakers to the denon sc2900 in the sound set up but still it will not work. Can someone advise how to fix this. This is very frustrating when I have paid for the licence and the software will not work. My set up is denon sc2900 x2 controller with behringer external mixer. Any advice would be a great help.
geposted Mon 22 Dec 14 @ 3:18 pm
have you a nvidia graphics card?
Hi, Not sure what the graphic card is, never looked, I will check later. I have just istalled a new software update from V1030 to V1168 for both my denon units so I will give this a try. Not sure if the updated VDj versions were not compatable with the earlier version software in the units. I have deleted VDj from my Pc but will now re install. Hopefully this will now all work properly now.
i have the same problem.
sometimes i can play only 2 min, then its freeze! or i can play 2-3 hour and the system freeze complete.
i have this problem only with hdmi or vga connection! without any connection the system runs perfect (and i play only video files) so there must be something wrong with the video/graphics settings but i don't know what....
with vdj7 i don't have this problem so i think there must be something wrong in the inside of the vdj8 version.
