Forum: Old versions
Topic: SBDJ SHOW LOGO ISSUE
hello here my computer's configuration :
when I want to use theSBDJ pluggin it's does not work , I would adjust the transparency but nothing to do.
it works with original pluggin but there is no option for setting.
Can someone help please ?
http://youtu.be/qvLU8nCoCIE
geposted Mon 22 Dec 14 @ 6:51 pm
Have you tried a different format - for example converting your file to PNG?
It could be failing to read your JPEG files.
thank you SBDJ it works very well with the PNG format , I had not thought : -S
Might be an issue with interleaved JPEG files; I'll have a look when I get a chance :)
