Hello All !
The problem I have is that they, both Vloop & Audioloop Out makes a very annoying "Stop Sound" in the end, like a vinyl break.
Wanted to check if anybody else have the same "problem" and if it could be fixed (no sound) ?
/Fredrik
/Fredrik
geposted Tue 23 Dec 14 @ 2:02 am
Perhaps Scott could help out ?
geposted Fri 26 Dec 14 @ 1:34 am
Over 100 viewers and no sound on my topic, am I the only one with this problem ?
geposted Sat 03 Jan 15 @ 1:28 am
Ok, thanks for take notice ;-)
geposted Tue 06 Jan 15 @ 1:53 pm
Just guessing here... What's the value from rampstoptime in options? Make it 0 and check if your problem is solved...
geposted Wed 07 Jan 15 @ 2:40 pm
Thanks Chreece, that was exactly what I needed ;-)
geposted Thu 08 Jan 15 @ 11:00 pm
