Will you add a Shader GLSL support to VDJ? Those files are really cool looking animations. See here: https://www.shadertoy.com/
geposted Sun 28 Dec 14 @ 3:53 pm
You can use GLSL shaders on the Mac version, have been able to since the Mac version was conceived.
You would use HLSL on Windows. It's generally very easy to convert between the two.
geposted Sun 28 Dec 14 @ 8:45 pm
Thanks for explanation. I've already found that those files are text files with .frag extension (GLSL), found some online editors for creating, but can you explain how to put those in VDJ's video output or respond to music? Are the GLSL files different and is there any converting tool (HLSL to GLSL)? Sorry for all these questions, but really can't find anything clear on the web.
geposted Mon 29 Dec 14 @ 3:02 am
I remember I've seen .fx files among DJDecks setup files, but that was too complicated in that time for me. Now, I can see similar effects in VDJ, but there are only .dll's. Is there a way to use .fx files in VDJ8 effects or it has to be compiled to .dll?
geposted Mon 29 Dec 14 @ 10:41 am
You'd have to wrap the shader in a plugin, including your own shader management and drawing.
You'll also need to do some form of audio processing (for example fft) and pass something from that to the shader too.
geposted Mon 29 Dec 14 @ 9:37 pm
I'm too scared to jump in programmer's water, combining those skills with my imagination would be pretty lethal for my free time. Just wish there would be some kind of plugin that would allow to add .fx file and make it respond to music. Something like Sonique plugin... Anyway, thanks for your answers.
geposted Tue 30 Dec 14 @ 3:46 am
Sure, I could do that easily enough, I already use HLSL and GLSL shaders in my plugins and have a custom library written to handle them.
It means you'd have to purchase a license to be able to use it though...
geposted Tue 30 Dec 14 @ 9:00 pm
Just found this cuttie on www.bazik-vj.com. It's a sound driven GLSL renderer on Windows, it's possible to use Spout and add it to a VDJ screen. It's using *.frag files on my Windows ultrabook. I thought Windows uses *.fx files, strange.
geposted Tue 27 Jan 15 @ 3:57 pm
The file extension is irrelevant; .frag is commonly used for GLSL fragment shaders though.
geposted Wed 28 Jan 15 @ 8:41 am
Well, there it goes... I installed this stuff:
https://magicmusicvisuals.com/
It allowed me to fool around with pixel shaders, there's a way to connect it to audio from VDJ over virtual audio cable. Also, you can send it's video stream to VDJ over the Spout (PC) or Syphon (Mac). There's a pixel shader additional pack:
https://magicmusicvisuals.com/resources
Just to make it hot! Milkdrop, Soundspectrum??? Who cares anymore?! ;-)
geposted Mon 11 Jan 16 @ 1:49 pm
