Hi,
Please would it be possible to add a feature to save all of the platter and slider moves, so that after an entire mix is done it can be edited to polish up the mixing of the set?
Thanks,
Richard.
Thanks,
Richard.
geposted Sun 28 Dec 14 @ 4:54 pm
Sounds like you need Ableton Live!
That's just the sort of thing which can easily be done in DAW software.
geposted Sun 28 Dec 14 @ 5:14 pm
Hi,
Yeah, the idea was inspired by the Ableton <> Serato Bridge software, so if there was a Ableton <> Virtual DJ Bridge, that would be good.
Then I thought it would be good if it could all be done within Virtual DJ.
I guess any way of doing the entire set roughly in Virtual DJ and then being able to edit it by whatever means would be a good enhancement.
geposted Mon 29 Dec 14 @ 3:09 am
I think recording the MIDI is something for the (probably distant) future for VDJ, but prior to release VDJ 8 did have a feature called Timeline which allowed tracks to be arranged in a sequence and for the mix crossover points to be edited.
Atomix changed their minds and removed it. People complained. People suggested it be brought back as an addon/plugin.
geposted Mon 29 Dec 14 @ 6:12 am
