Forum: Old versions
Topic: Loop Back/Forward using Shift+AutoLoop
Hi,
I have a DDJ-SX and VDJ 8, wanting to assign AutoLoop to loop forward, and Shift+AutoLoop to loop back.
Seems that the only option available for Loop back is either on or off (Switchable via options and tweaks), which means I can't have both?
Unless I assign Shift+autoloop to enable and then activate loop back, and autoloop to disable loopback and activate.
Is this possible?
Would anyone be able to help me with the command for the enabling and disabling of loopback?
Cheers :)
geposted Mon 29 Dec 14 @ 1:21 am
You can use the following scripts:
AUTOLOOP: setting "loopbackmode" no & loop
SHIFT_AUTOLOOP: setting "loopbackmode" yes & loop
Thank you kind sir!
