does anyone know how i can load a track and it just plays without having to press play everytime
geposted Mon 29 Dec 14 @ 7:33 pm
Hi mixin,
try putting it into automix and hit repeat in the automix options. QED.
all the best
ray
all the best
ray
geposted Tue 30 Dec 14 @ 3:01 am
Indeed, another way would be to put this on a custom button and turn it on
relay_play
Then put the desired track on both decks 1 & 2, but in all honesty Ray's method is better.
*Re-read the request, do you want to load and play? that's a remapping issue, whatever the load button, the script needs changing to
load & play
**Re-Re-read, the thread title tells me Rays method is the one you want, I've about 2 or 3 other methods that will suit certain scenarios but Ray's is the best cover all
relay_play
load & play
geposted Thu 01 Jan 15 @ 12:06 pm
