I have plugged my headphones into my laptop, and for some reason the left + right sound from my headphones is split, and plays only wear the crossfade bar is.
e.g when the crossfader is on the right, I only head out the right side of my headphones and vice versa.
I have never had this problem before. Does anybody know how to fix it so that I can hear out both sides of the headphones at the same time?
Thanks in advance
Thanks in advance
geposted Wed 31 Dec 14 @ 6:33 am
I'm sorry but the problem is your buildin soundcard.
The output is just a single stereo channle and it seems you use the split mode inside VDj which will send the left deck output (mono) to the left heaphone output
and the right one to roght headphone output.
You will need to use a DJ soundcard like the DJIO or just the single output inside VDj.
If you use version7, please have a look here:
https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20Audio%20Setup%20Guide.pdf
If you use version8, please have a look here at page 78 and 90
https://virtualdj.com/images/pdf/VirtualDJ8_User_Guide.pdf
geposted Thu 08 Jan 15 @ 6:28 am
