Forum: Old versions
Topic: Numark idj live 2
Hi there I bought a numark idj live 2 for my daughter we downloaded the virtual dj software through numark after registering the controller.
Once she started using it we seen the ten minute use time limitation so we bought the controller licence for £43 but now it's still the same.
Do we need to upgrade the virtual dj software too?
geposted Wed 31 Dec 14 @ 1:22 pm
The VDJ version that is supplied with/for the iDJ Live II is an LE version, which means that it's limited to use with that controller only.
There is no time limit on the use of any VDJ LE version when used with the intended controller.
That LE version will also be VDJ 7. The version you bought the license for is VDJ 8.
You will need to log in to VDJ 8 with your forum name and p/w for it to recognise that you've bought a license.
Ah I see happy days I'll try that thanks.
