Forum: Old versions
Topic: Akai LPD8 LED Problem
Hi All,
I have an Akai LPD8 which works great but I am having trouble keeping the LEDs for the pads lit (turned on). I currently have all the pads turned on normally, and blink when active (works great).
But, when I power it up, or when I change to another preset, then go back to a previous preset, all of the pad LEDs are turned off. I have to touch the pads to wake them up (have them light up). This is problem is true for all presets.
I know that I probably have to add a command to my map string(s).
Can someone please help me with what I need to do to fix this issue?
Thanks for your help in advance.
Clay
geposted Fri 02 Jan 15 @ 8:58 pm
I've a few mappings to look at but nothing new for the LPD 8, send me your mapping,
email pm'd
