HI !
i bought this controller ( cmd dc-1 ) to trigger fx and sample.
here is the mapping i made as the original mapping was not what i was looking for.
the only problem i have is this
i want this led : <map value="LED_BTN_JOG_BTN4" action="" /> to turn blue when pressed ( only amber an blue color for this controller)
same thing for this led : <map value="LED_BTN_JOG_BTN8" action="toggle " /> should be down ? on : off i think but it stay solid blue
and also if someone with good mapping skil can take a look at what ive done to correct thing if necessary
thank you !! :)
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="BeCMDDC1" version="800" date="2015-01-06">
<info>https://virtualdj.com/documents/Behringer%20CMD%20DC1%20VirtualDJ%208%20Operation%20Guide.pdf</info>
<map value="BROWSE" action="sampler_volume_master " />
<map value="BROWSE_ENTER" action="sampler_mute" />
<map value="BTN_JOG_BTN1" action="loop_double" />
<map value="BTN_JOG_BTN2" action="set 'shift' while_pressed" />
<map value="BTN_JOG_BTN3" action="sideview -1" />
<map value="BTN_JOG_BTN4" action="sampler_bank +1" />
<map value="BTN_JOG_BTN5" action="loop_half" />
<map value="BTN_JOG_BTN6" action="display_time "elapsed,total,remain" +1" />
<map value="BTN_JOG_BTN7" action="sideview +1" />
<map value="BTN_JOG_BTN8" action="sampler_bank -1" />
<map value="PAD1" action="sampler_pad 1" />
<map value="PAD2" action="sampler_pad 2" />
<map value="PAD3" action="sampler_pad 3" />
<map value="PAD4" action="sampler_pad 4" />
<map value="PAD5" action="sampler_pad 5" />
<map value="PAD6" action="sampler_pad 6" />
<map value="PAD7" action="sampler_pad 7" />
<map value="PAD8" action="sampler_pad 8" />
<map value="PAD9" action="sampler_pad 9" />
<map value="PAD10" action="sampler_pad 10" />
<map value="PAD11" action="sampler_pad 11" />
<map value="PAD12" action="sampler_pad 12" />
<map value="PAD13" action="sampler_pad 13" />
<map value="PAD14" action="sampler_pad 14" />
<map value="PAD15" action="sampler_pad 15" />
<map value="PAD16" action="sampler_pad 16" />
<map value="BTM_BTN1" action="var 'cue_shift' 1 ? var 'shift' ? delete_cue 4 : hot_cue 4 : var 'shift' ? delete_cue 1 : hot_cue 1" />
<map value="BTM_BTN2" action="var 'cue_shift' 1 ? var 'shift' ? delete_cue 5 : hot_cue 5 : var 'shift' ? delete_cue 2 : hot_cue 2" />
<map value="BTM_BTN3" action="var 'cue_shift' 1 ? var 'shift' ? delete_cue 6 : hot_cue 6 : var 'shift' ? delete_cue 3 : hot_cue 3" />
<map value="BTM_BTN4" action="var 'cue_shift' 1 ? var 'shift' ? delete_cue 7 : hot_cue 7 : var 'shift' ? delete_cue 4 : hot_cue 4" />
<map value="TOP_BTN" action="effect_active" />
<map value="TOP_KNB" action="effect_slider 2" />
<map value="BTM_KNB" action="effect_active ? effect_slider 1 : effect select" />
<map value="LED_PAD13" action="sampler_loaded 13 ? sampler_pad 13 ? blink 500ms : on : off" />
<map value="LED_PAD14" action="sampler_loaded 14 ? sampler_pad 14 ? blink 500ms : on : off" />
<map value="LED_PAD15" action="sampler_loaded 15 ? sampler_pad 15 ? blink 500ms : on : off" />
<map value="LED_PAD16" action="sampler_loaded 16 ? sampler_pad 16 ? blink 500ms : on : off" />
<map value="LED_PAD9" action="sampler_loaded 9 ? sampler_pad 9 ? blink 500ms : on : off" />
<map value="LED_PAD10" action="sampler_loaded 10 ? sampler_pad 10 ? blink 500ms : on : off" />
<map value="LED_PAD11" action="sampler_loaded 11 ? sampler_pad 11 ? blink 500ms : on : off" />
<map value="LED_PAD12" action="sampler_loaded 12 ? sampler_pad 12 ? blink 500ms : on : off" />
<map value="LED_PAD5" action="sampler_loaded 5 ? sampler_pad 5 ? blink 500ms : on : off" />
<map value="LED_PAD6" action="sampler_loaded 6 ? sampler_pad 6 ? blink 500ms : on : off" />
<map value="LED_PAD7" action="sampler_loaded 7 ? sampler_pad 7 ? blink 500ms : on : off" />
<map value="LED_PAD8" action="sampler_loaded 8 ? sampler_pad 8 ? blink 500ms : on : off" />
<map value="LED_PAD1" action="sampler_loaded 1 ? sampler_pad 1 ? blink 500ms : on : off" />
<map value="LED_PAD2" action="sampler_loaded 2 ? sampler_pad 2 ? blink 500ms : on : off" />
<map value="LED_PAD3" action="sampler_loaded 3 ? sampler_pad 3 ? blink 500ms : on : off" />
<map value="LED_PAD4" action="sampler_loaded 4 ? sampler_pad 4 ? blink 500ms : on : off" />
<map value="LED_BTN_JOG_BTN1" action="loop ? blink 1000ms" />
<map value="LED_BTN_JOG_BTN5" action="loop ? blink 1000ms" />
<map value="LED_BTN_JOG_BTN7" action="" />
<map value="LED_BTN_JOG_BTN6" action="" />
<map value="LED_BTN_JOG_BTN2" action="" />
<map value="LED_BTM_BTN3" action="" />
<map value="" action="" />
</mapper>
thank you !! :)
</mapper>
geposted Wed 07 Jan 15 @ 5:34 pm
one more thing is there any way to use the the 4 other knob that are for deck c and d to do other thing ?
geposted Wed 07 Jan 15 @ 5:37 pm
I guess you want the buttons to perform other tasks as well right ?
In that case you need to assign a variable and use it for the led:
Button:
play & set '$led1' while_pressed
Led_Button:
var '$led1'
Button:
Led_Button:
var '$led1'
geposted Wed 07 Jan 15 @ 5:58 pm
Button:
Led_Button:
var '$led1'
Button:
Led_Button:
var '$led1'
The action on that button is already what i want, I just want the led to turn on when pressed down im a noob on mapping is this command you give me will do that ?
geposted Wed 07 Jan 15 @ 6:07 pm
<map value="BTN_JOG_BTN4" action="sampler_bank +1 & set '$jbt4' while_pressed" />
<map value="LED_BTN_JOG_BTN4" action="var '$jbt4'" />
geposted Thu 08 Jan 15 @ 2:59 am
Thank you.
geposted Thu 08 Jan 15 @ 5:36 am
New problem : i was tweeking the mapping and for some reason it stop working.
if i choose factory setting it works
if i select my mapping nothing shows up
so i took the one i copied here and nothing.... still not working.
whats going on ?
whats going on ?
geposted Thu 08 Jan 15 @ 7:44 pm
all is good :)
geposted Fri 09 Jan 15 @ 5:14 pm
