Don't know if this is a bug or a setting issue
As you can see, the year is missing. Should be 2014...
Strange enough, but suddently...
Has anyone the same issue?
geposted Thu 08 Jan 15 @ 3:41 am
It depends on the date.
For October there's no confusion that it would be 2014, so the year is not necessary.
geposted Thu 08 Jan 15 @ 6:13 am
So, how do I know it is Oct 2014, and not 2013, 1998?
geposted Thu 08 Jan 15 @ 6:46 am
Because then it will say 2013 instead
geposted Thu 08 Jan 15 @ 7:02 am
but why is the 2nd picture showing dates with and without year?
geposted Thu 08 Jan 15 @ 7:04 am
The easy fix is to show the year on everything. I understand the thinking on the Atomix side here, however the thought is to keep it simple. (Anything that brings questions is not simple.)
geposted Thu 08 Jan 15 @ 9:37 am
The threshold is about half a year.
The reason to not always show the year is that it allows to show the time as well. Otherwise much more space would be needed for this column.
Time is more useful for recent dates than for dates a long time ago.
geposted Thu 08 Jan 15 @ 9:51 am
I noticed that when I made the transition from 7 to 8 (recently) that the first seen date info isn't imported from 7, so sorting by first seen has become useless to me for me.
geposted Thu 08 Jan 15 @ 12:20 pm
Unless you already had a v8 database.xml the first seen should be imported from the v7 database the first time v8 is run without a database.xml
geposted Thu 08 Jan 15 @ 12:44 pm
Okay thanks...
If you know that, it makes sense. But if you don't know it, it's just confusing...
geposted Thu 08 Jan 15 @ 2:41 pm
mine is showing everything i add with the year 2000 and the day and month are right... ??
geposted Thu 18 Feb 16 @ 12:02 am
if you are on V7 please check your account for 7.4.7.
there was a year 2015 bug that was fixed with the latest build
geposted Thu 18 Feb 16 @ 4:35 pm
