Hello,
I want to know how to change poi text size on waveform
geposted Thu 08 Jan 15 @ 11:28 am
Whick skin? Which waveform? Songpos wave/Scratch wave/Rhythm wave?
geposted Fri 09 Jan 15 @ 8:41 am
VirtualDJ 8:2 Decks skin, in Rythmwave that appear the name of poi
geposted Sat 10 Jan 15 @ 2:07 am
It requires editing the XML in the skin zip. Are you comfortable doing that?
The change is very simple. You will need to find the line and increase the font size from 14 to the size you want.
Which display do you use for the rhythmwave? Default/Mirror/Horizontal scratch/Extra grid lines?
geposted Sat 10 Jan 15 @ 7:26 am
Look for the browser info your may be diff you can change the color and size... then save to zip rename.
geposted Tue 20 Jan 15 @ 11:24 am
