Topic: Files updated after every song
Dropbox tells me the current history file and tracklist.txt are updated every few minutes, presumably when a track is registered as played.
Is this supposed to be the case .... I thought those files were only updated when VDJ is closed?
geposted Thu 08 Jan 15 @ 2:41 pm
And how do you store the infos which tracks are played?
Either create a temp file, write all infos into it, read it when VDJ is closing and write it to the tracklisting.txt and history?
That's too difficult.
Or you could store all the infos inside the app, but that will cost additonal RAM. Not good.
Best solution is to write directly into these files.
So I guess, yes, that's how it works.
geposted Thu 08 Jan 15 @ 2:44 pm
