Topic: Change log - Page: 1
I dont see the change log when vdj asks for updating??
geposted Mon 12 Jan 15 @ 9:27 am
Did you click on the word "Changelog" ?
geposted Mon 12 Jan 15 @ 9:56 am
yes i did it shows empty box
geposted Mon 12 Jan 15 @ 10:50 am
OldTomPRO InfinityMember since 2014
I saw the changelog when I updated yesterday. I'm running on Mac. Wondering if it may be a PC issue?
geposted Mon 12 Jan 15 @ 11:01 am
i use mac too but with dennyo skin when i updated it
geposted Mon 12 Jan 15 @ 11:02 am
Probably a point for another discussion-- but it makes me think that I made the right decision to stick with the plain vanilla VDJ8 skin. I've always wondered if the many skins available can sometimes affect performance in side issues like yours.
geposted Mon 12 Jan 15 @ 11:08 am
so many bugs
geposted Mon 12 Jan 15 @ 11:27 am
geposted Mon 12 Jan 15 @ 11:33 am
RobRoyPRO InfinitySenior staffMember since 2012
@Dj sam jad
Please klick on the "ChangeLog" Link ( blue) as you see here in the screenshot.
Then the ChangeLog will be visible
geposted Mon 12 Jan 15 @ 2:29 pm
geposted Tue 13 Jan 15 @ 4:00 am
Cannot confirm this.
Shows a emty box at the beginning, after klicking ... changed log was visible...
geposted Tue 13 Jan 15 @ 4:28 am
ok are you using the official skin of vdj or dennyo skin? when u checked the change log
geposted Tue 13 Jan 15 @ 6:11 am
Default skin...
geposted Tue 13 Jan 15 @ 6:21 am
The skin being used shouldn't make any difference. The popup box with the changelog doesn't originate from the skin.
geposted Tue 13 Jan 15 @ 8:24 am
well with the skins full of bugs sure it will happen,coz i use the skins and there are many bugs to mention
geposted Wed 14 Jan 15 @ 8:10 am
As groovin said: This popup window is in no relation to the skin used.
It's generated "internal" in VDJ.
And btw: I'm too using the dennyo skin and don't have this problems.
geposted Wed 14 Jan 15 @ 8:26 am
Please check if any Antivirus Software or Popup Blocker on your system could possibly cause this issue or behaviour...
geposted Wed 14 Jan 15 @ 8:59 am
dcomoPRO InfinityMember since 2012
I typically use the default skin since I have seen odd crashing issues with other skins. (There's a number of problems with the DennYo skin on Mac which causes VDJ to crash out.)
Better be safe than sorry...
geposted Wed 14 Jan 15 @ 9:43 am
I have a MAC Book Pro and no change log for me. Where the heck is it whenever I want to see it?
geposted Thu 19 Feb 15 @ 8:19 pm
I updated my VDJ today and the changelog link showed up and I clicked. It showed a blank box. Why can't the changelog also be on the website where it says What's New in VDJ8? I'd like to see what's happening in the background. It can be helpful sometimes when troubleshooting. Please fix or post a link on the website. I'm using the OEM skin too.
geposted Thu 19 Feb 15 @ 8:24 pm
91%
