Discussion about FixVirtualDJHosts PC
geposted Tue 13 Jan 15 @ 12:15 am
And on the third day the pirate decided that low V8 was good and the skanky hacks did'th not'th do it justice, the pirate entered communion with Atomix with offers of money,
And SBDJ said, "New user, thou art a sinner but thou art forgiven, seek salvation with this .bat file"
sclavel saw this and it was good.
geposted Tue 13 Jan 15 @ 1:46 pm
Saw this on the addons page but I don't understand what it is or what it does. Would someone please explain this in Laymans terms? Thank you
geposted Tue 13 Jan 15 @ 4:23 pm
The V8 hacks out there, mess up a system file so V8 can't connect to atomix HQ, this addon fixes the messed up file for users who've abandoned the dark side.
Unless you've used hacked software this addon is useless to you.
geposted Tue 13 Jan 15 @ 4:31 pm
Ok got it. Thanks. Yep, no use to me.
geposted Tue 13 Jan 15 @ 5:06 pm
I click on FIXVIRTUALDJHOSTS Pc, then in DOWNLOAD and the system said "SORRY, THE LINK YOU HAVE USED IS NOT VALID ANYMORE. What can i do?
geposted Tue 11 Aug 15 @ 11:53 am
Downloads fine here. Try again?
geposted Tue 11 Aug 15 @ 4:10 pm
I was once a sinner but now I know the light (not DMX in this case). I have found salvation in the word (code) of "V8"
Atomix be praised!
Atomix be praised!
geposted Thu 20 Aug 15 @ 12:32 pm
Not working for me...
geposted Tue 22 Dec 15 @ 1:14 am
repent and thou shall be saved, i have seen the light. thank you for showing this lost sheep the way. - Wee Stevie 8-)
geposted Fri 19 Feb 16 @ 11:25 pm
It works for me now every thing is fine
geposted Wed 02 Mar 16 @ 11:02 am
When I download the file I get an error message saying "Host File Not Change" anyone know how to fix this?
geposted Mon 18 Apr 16 @ 4:55 am
It means there was nothing for the utility to remove; ie there was no need to use it.
geposted Mon 18 Apr 16 @ 1:37 pm
Thanks Masters! But i was in a rush & reset my new exchange laptop. Problem solved! The dark side touched me but not change me. I have a new beggining! "May the force be with you"
geposted Sun 07 Aug 16 @ 1:05 pm
it says host file not changed! what dose that mean?
geposted Wed 21 Sep 16 @ 1:50 am
it dont work
geposted Wed 21 Sep 16 @ 5:32 am
If the host file isn't changed then either it didn't need to be changed or it couldn't change it.
Check the file c:\windows\system32\drivers\etc\hosts to see if there is any reference to virtualdj.
geposted Thu 22 Sep 16 @ 1:34 pm
Hello ......I bought the virtual dj lic
geposted Mon 03 Oct 16 @ 4:18 pm
Hi there...I bought the virtual dj license but every time I try to login it keep telling me it can't connect to servers
geposted Mon 03 Oct 16 @ 4:19 pm
Have you tried the addon, checked your FW, tried with whatever security you have switched off [thinking like the worst offender Norton]
geposted Mon 03 Oct 16 @ 6:05 pm
