Forum: Old versions
Topic: update not working
Hi guys iv been holding of doing the updates as it keeps cleaning my playlists every time. I have just tried running the up date at start up and it says its failed would I like to try agian. Iv done this 5 times and the same thing. I have Not firewall on and all AV's are off.. any clu ?
Thanks for your help before hand.
Sam
geposted Wed 14 Jan 15 @ 11:43 am
Check Task Manager for multiple copies of virtualdj8.exe and end them all, then try again.
This is an old issue which has been reported many times.
I've had 10 or more running sometimes!
sorted, Thanks Max.. A*** Software
