Lo siento, no hablo español. ¿Puedes preguntar en inglés?
geposted Fri 18 Aug 17 @ 12:45 pm
How do I change or add just one exterior drive database from v8 to v7 and use both versions on the same drive.
geposted Tue 13 Aug 19 @ 2:24 am
Could you please explain how I can convert a v8 database file in a USB external drive to v7 format?
Thanks for your help....
geposted Thu 15 Aug 19 @ 6:27 pm
It's been a while since I did this program. I'm not entirely sure atm if it's possible.
I'll get back to you in about 12 hours.
geposted Thu 15 Aug 19 @ 6:32 pm
Thank You for the reply...
geposted Thu 15 Aug 19 @ 10:59 pm
Okay, I Tried this again and see an error massage that there is an error in the database, but it does work in V8 with no issues.
What can I do to fix this issue?
Thank You..
Thank You..
geposted Sat 17 Aug 19 @ 12:59 am
This is the error message I get "Could not find a part of the path 'H:\VirtualDJ\folders'."
Thanks...
Thanks...
geposted Sat 17 Aug 19 @ 9:43 am
Screen shot of the error message when trying to convert my external drive H:
geposted Sat 17 Aug 19 @ 5:25 pm
Joey, I'm sorry I'm busy atm... Could we establish an appointment this week over TeamViewer? I'm not sure what the problem is or what you are trying to accomplish.
Drop me a PM
Drop me a PM
geposted Sat 17 Aug 19 @ 5:55 pm
I did a little experiment and copied the v8 database into my internal D:\ drive to see if it would convert there, well it did work with no errors this time, but not sure if the results are correct. See the comparisons in database size in image?
Please take a look at this and if need be I'll PMU.
Thanks..
Thanks..
geposted Sat 17 Aug 19 @ 6:10 pm
Well it is possible that the size is correct.
Since v7 did store less Infos in the DB. And whitespace sum up too.
But I need to compare both files to give an absolute answer.
geposted Sat 17 Aug 19 @ 6:25 pm
Okay, I'll check this out with v7 first and if it doesn't look good I will post a DropBox link with the two databases.
geposted Sat 17 Aug 19 @ 6:29 pm
