With this tool you can create different profiles, vdj8 and settings we call when we need them. e.g.
a karaoke profile, profile controller ergo, profile controller Hercules mp3e2
https://virtualdj.com/plugins/?addonid=80186
geposted Thu 15 Jan 15 @ 8:29 am
update 1.3
Add four memory locations, for direct and quick withdrawal of profile.
fix small bugs
fix small bugs
geposted Wed 28 Jan 15 @ 12:49 pm
update 1.3.1
fix bug sometimes not save in memory slots
geposted Mon 02 Feb 15 @ 12:41 am
Great thanks on you for the nice Plugin and the Support.
greatings,Dirk
greatings,Dirk
geposted Fri 06 Feb 15 @ 1:46 pm
greatings,Dirk
greatings,Dirk
thanks!!!
Mini update 1.3.2!
Now running and in winxp without problem!
Enjoy!!
geposted Fri 06 Feb 15 @ 2:20 pm
new update! 1.4.4
containment Last selected folder (saved for the next session)
containment Last date from the tracklisting.txt file
containment of memory locations after new update or change the position of the program!
geposted Mon 09 Feb 15 @ 4:00 am
I thought VDJ could already do this on it's own??
geposted Mon 09 Feb 15 @ 10:41 am
At first I thought that too, but VDJ only could save different Audio settings, not different settings.xml aswell.
geposted Wed 11 Feb 15 @ 4:37 pm
PachN wrote :
Maybe I'm just to stupid, but... how does it work?
Where do I have to copy the assambly? Because every time I click on your logo in the middle of the program, or if I create a profile, add it to a memory button and click on that memory button I get a "FileNotFoundException".
To ask a question?
You changed the name of virtualdj to something other than the "virtualdj8 .exe"
e.g. "virtualdj.exe"
geposted Thu 12 Feb 15 @ 7:21 am
No, why should I do this?
I never touched the vdj.exe other than to start the program.
And even for that, I use a shortcut from desktop.
I also have not changed the default program or document path or anything.
geposted Fri 13 Feb 15 @ 5:07 am
new update! 1.5.2.0
fix create-update saving profile when it is open vdj
new 5 skin colors
new 5 skin colors
geposted Tue 24 Feb 15 @ 1:15 am
update 1.5.3.0
- Add remember function "rootFoldersLocation"
- New function for beta testers((only for beta testers vdj)
geposted Sat 08 Apr 17 @ 5:14 am
