Forum: Old versions
Topic: Pro Monthly license ($19/mo.), setup contol?
So I purchased the pro monthly license in which I have the ability to use my Hercules RMX controller. Or, at least according to info I read. If I misread it, can you let me know. If not, when I open Virtual Dj, I originally downloaded the free one before the purchase, how do I setup to controller to work? I already downloaded the updated drivers, as well. Thanks for the help!
geposted Fri 16 Jan 15 @ 12:10 am
There shouldnt be much to do once the drivers are installed.it's a plug n play unit.
The link above is for version 7, so disregard it.
Normally a pop-up detection message will appear (unless you have not plugged the unit for the first time).
The Audio configuration is pre-defined and a special button should be available in the AUDIO tab of the Settings window.
You may have to install a special skin though in order to use/select the actions of the djc_buttons.
Currently the only available one is https://virtualdj.com/plugins/?addonid=80162
