Been using VDJ 8 with the Pioneer Ergo Since 8 was first realesed with basically no problems.
Updated to the SR just over a week ago and seemed to work ok straight up. Done two basic gigs last weekend and everything seemed ok.
Last night done a gig where i needed to use the controller a lot more and noticed it seems to trim it self when using volume sliders to mix then having to turn the trim knob to lower volume then back up again to get full volume.
Also couple of times I tried to loop a song on the qued deck and it enabled the loop on the master playing deck.
Also when i went into configurations and tried to apply sound settings it back spun the playing track and crashed VDJ.
Also sometimes when you try and click on a song to drag it too a deck to load it won't react and you have to try a couple of times for it to react.
Never had any of these issues with the Ergo.
Got another gig tonight and I'm now really paranoid with this controller and VDJ 😕
geposted Fri 16 Jan 15 @ 4:15 pm
