Forum: Old versions
Topic: Denon dn-x600 with v8
Are there any issues using the denon dn-x600 with virtual DJ 8? is it supported by default? does sound card for dvs and midi work fine?
Thanks...
geposted Sat 24 Jan 15 @ 10:20 pm
There is no built in definition for this device. It will work, including for DVS, but you would have to set up the audio manually and do any MIDI mapping manually too.
I see there is a definition ... BUT I think it is for V7. Will this work? does anyone know how to create one?
Can I use VDJ8 with a MacBook Pro using the Denon DN-X600 or the NuMark DJIO2 sound card
Please help with step by step instructions! - Thank you!
