Forum: VirtualDJ Skins
Topic: VDJ script
Hello,
I would like to see beat value in my cue window for example simple 32 not 32.3 or 32.8 etc. So the info would not change so quickly.
How to change : format="%PBfromcuen"/> in VDJ script for VDJ7?
Thanks for your time friends.
geposted Sat 24 Jan 15 @ 10:41 pm
There is no way to change the behavior of this action at the moment. By default it provides an integer number if the distance is more than 4 beats and a more accurate decimal number if less.
geposted Sun 25 Jan 15 @ 5:22 pm
Hello ,
thank you for your time.
Anyway I was wrong 3.2 or 3.8 no 32.2 or 32.8 as my example, so there is not problem for me at all.
You explain it very well. integer....hmmmm missing in my dictionary...
Best regards
geposted Mon 26 Jan 15 @ 4:01 pm
basxrPRO InfinityMember since 2011
madlenm wrote :
integer....hmm
integer would be : .... -2 , -1 , 0 , 1 , 2 , 3 ...... only whole numbers
ZZZZZZZ.
geposted Mon 26 Jan 15 @ 4:11 pm
