Recently chriso710 mentioned that he liked the DEX 3 video skin, so I took a look and discovered that their skinning system is now very similar to the VDJ code.
As most of the hard work was therefore already done, I thought I'd have a go at converting a skin.
A bit of Googling has revealed that DEX 3 is effectively the same as some software called FutureDecks DJ Pro - and both programs have free skins. :-)
geposted Sun 25 Jan 15 @ 12:22 pm
Update: I've now also converted the audio skin and added it to the zip, so it can be switched between audio and video.
Four deck variation still to do. :-)
geposted Mon 02 Feb 15 @ 7:50 am
Brilliant conversion groovindj, will it be available soon to download?
Thanks.
Thanks.
geposted Tue 03 Feb 15 @ 11:55 am
I would really like this skin can anyone help i cant find it
geposted Fri 06 Apr 18 @ 12:52 pm
Looks like it was never posted.
geposted Fri 06 Apr 18 @ 2:20 pm
acereflections wrote :
i cant find it
.....and you never will. It was my own personal project.
The skin will never be approved by Atomix as it's an exact clone of another DJ program. I really only posted pics to show as an example because I was learning to skin, and the conversion was simple. I knew it would not be approved - that was never the plan.
I wouldn't have made it available to non licensed users anyway.
geposted Fri 06 Apr 18 @ 5:01 pm
if i buy the licence will you share
geposted Sat 07 Apr 18 @ 6:56 am
