Forum: Beta Builds Regression Bugs
Topic: BUILD 2135 - Page: 2
locodog wrote :
Ran into the tag editor crash, not in optimum usage (defragging at the time)
Hallole,
i have the same Problems to open the Tags.
95 % V8 crush and restart.
Some mp3 open, but when i open this file a second time v8 crush.
Mouse or Mapping it is the same Problem!
LG Bobby
Traduction Google
Good Morning
I have a big problem with the new update version 8 B 2135.
when you click to open the virtual tag editor closes. (2 on my computer)
@BLUE NIGHT oui, le problème est connu.
Writing comment in Tag Editor, click "write tag" *immediate crash* 2135-917
OS X Yosemite
10.10.1
No point installing this if it's crashing .......
Gear-
-Using MBP w/Retina
-Numark Mixtrack Edge
- Skin in use "Controller by DennYo"
Loading a track from a shortcut folder generated the following sequence:
1. VDJ8 shut down after about 10 min of mixing
2. Automatically restarted
3. Track did not continue to play on restart as with past issues like this. This time wave forms studders but no music.
4. VDJ8 lost connectivity with controller
5. Keyboard shortcut "Rescan for controller" wouldn't reconnect to controller.
6. Finally, I closed the program and restarted. No crash after about 5 min of use.
Will experiment again today.
2crash in 30min playing with DDJ-ergo it open back up this time....This is New..doing this OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
Here the same problems.
First crash when loading a song, after crash I can load the same song but when I click file-info also chashed.
Did try this at pc (vista) and laptop(w8) and same problem.With vdj7 no problems.
Can whe undo last update?
Just reverted back to a previous build. I tried loading Beta 2135 on my back up Mac Air and the entire system hung. Finally had to to a reboot of the computer.
Batch reload tags crashes VDJ reproduceable when the selectet files are in several folders.
Also experiencing crash when recursing, opening folder, or any batch item. rolling back to latest stable fixes it.
crashed constantly when editing tags
also noted when installed the beta, sidelist was wiped clean (no file) in folder. Luckily I had a backup of my vdj folder before update.
I have uninstalled and went back to previous build as this beta is unstable :(
