Forum: Old versions
Topic: Help with adding my music collection
Hi I am trying out Virtual DJ 8 on Mac Mavericks 10.9.5. Every time I try to import my music folder Virtual DJ 8 crashes and then re-opens. I followed these instructions:
1. Navigate to your folder in browser pane
2. Right-Click on that folder
3. Select Add to DB search
By the way I do have over 3,000 songs in my music folder. Any help would be appreciated.
geposted Wed 28 Jan 15 @ 10:23 pm
Please be so kind and try to use the latest build.
Should be solved with the latest update.
If not, please try to find the file which will cause the crash.
We would need to have the file for a look.
Hi, thank you for your reply. I have downloaded the latest build from the downloads page. Also how do I find which file is causing the crash?
Thank you again!
