-Fix regression crash from b2136
-Fix ghost slider problem with master controls
-Fix 'days left' license text for some languages
-Security window always on top
-Fix Sonique not working
geposted Thu 29 Jan 15 @ 8:14 am
my cpu lock step to 15 % , now 25% , idk if it will be a fix ...
geposted Thu 29 Jan 15 @ 2:55 pm
These posted crash reports really need to be dealt with somewhere else, they interfere with the flow of the pages.
geposted Sat 31 Jan 15 @ 5:09 am
I have noticed a drop in the volume output from my CDJ2000nexus. This happened since the previous update. Not sure if anyone else noticed this.
geposted Sat 31 Jan 15 @ 5:48 am
last night 5+ hour spin with v2139. Great stability etc!
however these things really interfered with my DJ ing flow. posted in the appropriate place:
https://virtualdj.com/forums/198023/VirtualDJ_8_bug-report_Forum/Pretty_stable_____however_these_things_are_flowkillers____________(plz_fix_or_advice_workaround).html
geposted Sat 31 Jan 15 @ 6:14 am
Not bugs. You need to spend more time with the software and get to know it better.
geposted Sat 31 Jan 15 @ 6:33 am
I make a living from it 15hours + a weekend. But if you have suggestions be my guest
geposted Sat 31 Jan 15 @ 7:53 am
2139.928
PC Win7/64bit , i5 2x2.8ghz, nvidia 840m, 16gb ram
last night after playing 5 hour with video, i open the "text" plugin and write " Party End " vdj8 freeze complete (combination with slide show). can't close vdj8! only a hard shutdown was possible.
geposted Sat 31 Jan 15 @ 8:27 am
DEV please look at timecode vinyl when scratching there is a glitch using windows 8.1 sl3 soundcard serato timecode vinyl this glitch is not happening on a mac book please who in charge of timecode vinyl on the DEV team there is a problem when scratching i try everything on the software setting and nothing on a mac book this is not happening i try it on my friend mac book and scratching is good windows it is not my computer is ASUS Q55LOF I7 16 GB RAM GRAPHIC CARD IS NVIDIA GEFORCE 745M .PLEASE i am a heavy scratchier and do tricks to i'm not able to this because of the glitch. on serato this does not happen i do not no why this is happening to VDJ 8.Please let me know what i can do to fix this .thank u
geposted Sat 31 Jan 15 @ 11:45 am
... after 8 hours closes unexpectedly
... working with audiovisual effect, ie mp3, the effect slishow not return to video
... after three hours audio desafa
geposted Sun 01 Feb 15 @ 12:12 am
RE: My crash post posted above...
Apparently the crash report posted isn't related to the regression, doing further checks on my computer it seems that there is a software issue with yosemite 10.10.2
moderator can remove that long crash report above.
Thanks
Thanks
geposted Sun 01 Feb 15 @ 7:26 am
used this version all weekend @ 3 gigs. All perfectly stable: 4decks browserview skin / 2 active line inputs etc etc. Great work!
geposted Mon 02 Feb 15 @ 9:52 am
Deck load Safety do not work... Fader on top, song is playing, in settings i set this safety on... but i can load a new song
geposted Tue 03 Feb 15 @ 3:44 am
Security has not worked for a while now.
geposted Tue 03 Feb 15 @ 4:27 am
Working here. Anything specific about your configuration you can think of?
geposted Tue 03 Feb 15 @ 6:09 am
Not really, I also checked the settings.xml to make sure it was OK in there.
I guess deleting the settings.xml file might cure it but then I lose all my specific settings and skin global variables so I don't really want to go there!
Keith
Keith
geposted Tue 03 Feb 15 @ 6:24 am
Hmm, i use DJ Dad combat mirror skin... i will check it, with another skin and Pioneer DDJ SR Controller
geposted Tue 03 Feb 15 @ 7:08 am
I just tried to duplicate the issue - and yes, when using Combat mirror, the load security is ignored. The playing track is replaced by a new dragged track.
When using another skin, this does not occur. The security warning pops up.
geposted Tue 03 Feb 15 @ 7:26 am
It appears to be a bug in this skin, with 2 drop zones overlapping for a single deck.
geposted Tue 03 Feb 15 @ 7:37 am
So this is not permissable?
<group name="deck1_drop" >
<dropzone visibility="var '@$panel1' 1">
<pos x="+0" y="+0" />
<size width="752" height="260"/>
</dropzone>
<dropzone visibility="var '@$panel1' 0">
<size width="752" height="260-55"/>
</dropzone>
</group>
Two dropzones but only one "active" because there's a visibility variable.
</dropzone>
</dropzone>
</group>
geposted Tue 03 Feb 15 @ 7:48 am
