Topic: slicer pads bug
the slicer pads(1>8) are not working has before (2094) for ex: when I'm pressing pad 1 then go to pad 2 I must keep pressing pad 1 or the slice FX wont work on pad 2, then If I "unpress" pad 1 slice FX will shut off for slice pad 2, and I cant go back to slice pad 1...I hope I'm beeing clear.
looking forward
thank you
osx 10.7 stanton scs1 system
geposted Thu 29 Jan 15 @ 12:20 pm
just tested previous builds and the regression bug on slicer pads happens on b2126>2139, its ok on 2117 and previous.
anyone using slicer FX pads that can confirm this??
thank you
Are the Slicer pads assigned as .. slicer x .. or something else too ?
the pads have diferent variables, but when in slicer mode yes, only one midi command "slicer x"
"PAD_1"
var 'padmode' 1 ? var 'mode1bank' 0 ? loop_in : var 'mode1bank' 1 ? loop_half : var 'mode1bank' 2 ?  loop_load 1 ? holding 600 ms ? loop_delete 1 : loop_load_prepare 1 : loop_save 1 : var 'padmode' 2 ? nothing : loop_roll 0.125 : var 'padmode' 0 ? hot_cue 1 : slicer 5
and "TRIG_BTN1(2,3,4)_UPR"
var 'padmode' 1 ? set 'mode1bank' 0 : var 'padmode' 2 ? slicer 1 : delete_cue 1
here is the mapping if you care to take a look
https://virtualdj.com/forums/195728/addons/SCS1d_-_SLICER_PADS.html
thank you
Can you try to assign the buttons just as slicer x and see if it works correctly ?
just tried mapping keyboard keys for the slicer (slicer 1,2,3,4) and the behavior is the same, when I press pad1,then 2, if unhold pad 1, sliced fx on pad 2 will shut off.
before b2117 it had the same behaviour has the loop roll, when pressing pad 1 sliced fx first beat, then while holding pad1 press pad2 it would slice fx beat2,then unholding pad2 while still holding pad1, the slice fx would be again on beat1.
thank you
edit: just tried on the mac+scs mapped the pad only for "slice x" and its the same result
I'm using the Slice FX in this video at 0.45s > 0.50s and 2.14s>2.20s jumping between sliced beat/pad 5,6,7
Ok indeed there is an issue with sequential slicer buttons. Reported.
sclavel wrote :
BUILD 2144 - BETA -
-fix slicer multiple button presses
fixed!
thank you
+1 for that, I was gettin it on my Reloop Neon as well
sclavel wrote :
Build 2151
-Fix some problems when using slicer actions with Slicer not selected in a slot
confirmed.I have a midi button to switch between,lenght 1/2 and 1/4 , I was guessing it was a midi or script issue.
thank you
