Currently there is no way to prepare a video track on the 3rd or 4th deck because pressing the corresponding for them button (3 or 4) is making them direct the master video deck.
Also if a VDJ want to have the crossfader on the middle to mix on the fly (press play on the moment you want to mix in without moving the crossfader) then the paused deck is also outputed on the master.
Both of the problems could be solved as i have already suggested:
Output a deck on Master Video only when there is a sound played from this deck...
It's not hard at all to code and it would enable all the VDJs to use all 4 Decks of their controllers....
Where are all VDJs??? Don't you use 4 decks???
geposted Thu 29 Jan 15 @ 2:49 pm
