I've run into a behaviour that was not happening in prior builds (can't say when exactly it started as I don't frequently do video shows - but I noticed it for the first time two weeks ago).
I use clips in the video sampler when playing audio files. Video samples won't display unless I have the volume for the sampler set to full. I have the video upfader link set to off in options (and it is off for the decks) but it remains on for the sampler. As some of the samples I use have background audio - that's a wee bit of a problem for me...
Looking for suggestions or a fix. Thanks!
geposted Sat 31 Jan 15 @ 6:47 pm
This is by design; if you lower the gain on your audio sample then you won't have to reduce the sampler volume and your samples will then display without fading :)
geposted Sat 31 Jan 15 @ 7:18 pm
But you want to have the gain of the sample to be set at 0db for cases when it's played in solo and then drop the volume slider for cases when multiple samples are used.
The current Atomix company line on sample gain is lousy, incorrect and makes work.
geposted Sat 31 Jan 15 @ 7:33 pm
So by design the video sampler ignores what I have specifically set in options? That seems rather counter-productive, but okay, assuming I follow that line and want to adjust the gain of the sample, is there somewhere outside the sample editor to do that? Because the video samples I downloaded won't access the sample editor - some sort of error about compressed sample packs?
geposted Sat 31 Jan 15 @ 7:40 pm
No. The limiter will drop out anything played at too great of a volume. The advice given was sound.
geposted Sat 31 Jan 15 @ 7:51 pm
TearEmUp - I don't think you understood the problem if you think the limiter is in any way involved. I'm trying to get a video sample to play without volume. I can't leave the volume of the sampler down because that now forces the sample to black AND and I can't access the gain control to turn the volume down as the sample editor won't load for these samples.
geposted Sat 31 Jan 15 @ 7:56 pm
Unzip the samples and you can edit them
geposted Sat 31 Jan 15 @ 8:19 pm
I agree it's daft that we're expected to adjust gain (which then requires a save) instead of being able to adjust volume on the fly and have it remembered (as it was in VDJ 7).
With this particular situation though, it's even more ridiculous.
Why shouldn't someone be able to play a video sample without sound by lowering the sample volume? That's how you'd expect it to work.
It's sample volume - why is it fading the video out? :-/
geposted Sun 01 Feb 15 @ 10:00 am
