-Fix Netsearch video
-Fix crash trying to disable audio only visualisation from plugin interface
-Fix potential crash decoding videos
- Other and AutoStart plugins now loaded if user logs in after startup
- Only allow one load point to be set in POI editor
-param_contains fixed
-bug with some param_multipliers being executed twice fixed
-right-click on sideview shortcuts to remove a specific shortcut
-fix slicer multiple button presses
-fix some mp4 tag writing/reading bugs
geposted Tue 03 Feb 15 @ 6:21 pm
Hello, because in free and paid version, mostly free (does not show the file name in place of Title?
Ola, porque na versão free e paga, principalmente free (não mostra o nome do arquivo no lugar de Titulo ?
geposted Tue 03 Feb 15 @ 6:51 pm
Hi..
this is a topic for regressions bugs according to specific builds.
Please feel free to open a new Topic in the general discussion forum:
https://virtualdj.com/forums/30/General_Discussion.html
geposted Wed 04 Feb 15 @ 5:06 am
At the club and no CU. Internet is good, that's how I'm posting. This includes Netsearch, which is not really big on my list.
geposted Wed 04 Feb 15 @ 4:38 pm
Tonight using Mac Air experienced a VDJ8 Close and automatic reboot.
No controller in use.
Track playing on deck 2
I dragged two highlighted tracks from the Side Bar to the Automix pane.
System closed and restarted in about 3 seconds and music kept playing but any work I hadn't saved was gone. The track loaded on deck 1 was also still loaded.
Tried to replicate but haven't been able to.
geposted Wed 04 Feb 15 @ 9:23 pm
I don't know what's going on. At home now and CU works. At the club this afternoon, it would not work with wired, wireless, or my phones hotspot. I was able to get internet access, and able to post to the forum. Now CU works wired, wireless, and on my phones hotspot. So, what am I doing wrong?
geposted Wed 04 Feb 15 @ 9:56 pm
build 2144, pc, win 8.1
Re-Analyze and or batch Analyze is putting the AM points in the wrong places/order once again!
In one of the builds it was working perfectly, but I can't remember which one, sorry.
is also happening in the last public build
ray
ray
geposted Thu 05 Feb 15 @ 5:46 am
I seem to have had lots of crashes with this build. Most were related to refreshing tags after using Mixed In Key 7. But, one or two were when clicking on a folder in the left navigation window. The crashes/restarts should have been automatically passed to Atomix.
Gone back to the previous Public build.
geposted Thu 05 Feb 15 @ 7:01 am
It looks like it is crashing on some mp4 files.
Is it possible to find one of the crashing files and send it to me?
Opening the tag editor on such a file will probably cause the crash as well.
geposted Thu 05 Feb 15 @ 8:32 am
On my numark mixtrack quad (custom config), whenever i touch the wheel (to nudge forward or back) it shuts down VDJ8 then restarts it, also the swirling light which depicts the rotation of the deck is stuck at what looks like 11.55, it only changes when the song is 30seconds to finish. So far it did this 4 times so far. will report later if anything else odd happens
geposted Thu 05 Feb 15 @ 6:28 pm
I think I found the issue, Somehow this update caused the RPM to set itself to '0', so when I touched the wheel it first stopped the track, then rebooted VDJ8, this happened now 6 times, I've now set the rpm to '1' (which is how I like it) and now it's fine again (phew), although why it caused it to reboot is a bit odd
geposted Thu 05 Feb 15 @ 10:19 pm
@Adion - Crashing mp4 file link sent in PM.
geposted Thu 05 Feb 15 @ 10:21 pm
Thanks, I didn't get a PM yet though
Edit: Got it now. Bug will be fixed next build.
geposted Fri 06 Feb 15 @ 4:47 am
after finally getting this stable (for me). this build crashed twice on me last night. mc6000mk2 with hp envy17
geposted Fri 06 Feb 15 @ 11:56 am
the scratch H-split is not moving smooth now.OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Fri 06 Feb 15 @ 5:44 pm
Not sure if a regression bug or feature. While logged into my desktop VDJ8 using a Denon controller, my laptop also showed me logged in as well and did not tell me it was in use. And after a few hours, my sound would drop out - like someone pulled the USB. Once I reset the USB and logged out of and back into VDJ, it went away. Posted in detail in main bug forum in case.
Puzzling...
Puzzling...
geposted Fri 06 Feb 15 @ 9:14 pm
the headset sound mixing console , deck a or b selects not allowed to return to cueing master ...
geposted Fri 06 Feb 15 @ 9:24 pm
wing version regarding the cpu climbed above 10 percent ...
geposted Fri 06 Feb 15 @ 9:27 pm
Same problem....
In My. Rmx console
geposted Fri 06 Feb 15 @ 9:55 pm
saturated bass sound in sub you record ...
geposted Fri 06 Feb 15 @ 10:29 pm
